Snapping stopped working in H 20?
   1973   5   0
Can someone check snapping in H20 ? I tried to connect gizmo to points or polygons both at the sop and obj level - there is absolutely no binding anymore. Maybe something has changed in the settings ? Or is it a bug ? Unclear.
Maybe you are using your keymap from H19.5?
https://www.sidefx.com/docs/houdini20.0/news/20/hotkeys.html [www.sidefx.com]
Cheers
CYTE
No, I use a mouse. if you are talking about calling the alignment handles via ; and ' - then they are called without problems. But gluing to a point or polygon doesn't work. Here is an example on geometry.
bandicam 2023-11-09 17-38-30-427.mp4 (2.6 MB)
Im not sure if I understand completely, but snapping works on my end.
If you haven't already delete your preference folder and start from scratch?
Im just saying because I have my own fair share of problems with keybindings and stuff...
Edited by CYTE - Nov. 9, 2023 09:51:06
Great. Indeed, deleting the settings folder helped.
I figured it out. The problem was running Vulkan in houdini.env. Keep that in mind.
