The viewport rendering time jumps from 1 second to 40 second
1614 3 0-
- HGaal
- 102 posts
I create a simple model in the Karma viewport. And I see that the final rendering time is sometimes 1 second, but sometimes when rotated by a few degrees, the time becomes 20-30-40 seconds. Then again 1 second, then again 30 seconds. Can someone explain what the trick is here? Neither the model nor the lighting changes, and the samples are very low.
Edited by HGaal - Nov. 15, 2023 05:43:46
- CYTE
- 803 posts
- HGaal
- 102 posts
- jsmack
- 8183 posts
HGaal
Figured it out a bit. This is clearly a bug. If there is no camera in the scene, then karma behaves so strangely. If you add the camera, then everything is fine and works quickly.
are you seeing both devices contribute when it takes longer, or just one? You can see the status next to the device name (idle, X%, compile, init, error)
