OpenGL Houdini error
   2335   2   0
hi. i faced with "Your driver settings have been set to force 2x Antialiasing in OpenGL applications. This will cause visual artifacts in Houdini. It is recommended that you turn this off in the graphics driver." error. I'd tried to turn opengl antialising in NVIDIA CONTROL PANEL (my graphic card is gigabyte and processor is RYZEN) But i can`t do that (watch screenshot). By clicking on marked option i can choose only 2x / 4x /8x, but i can`t turn it off. What should i do?
houdini error1.PNG (3.4 KB)
Don't worry about it. The viewport is just a guide. What you render is what matters.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
If you don't have any way to disable it (which seems a little weird), set it to 4x. The viewer requires at least 4x MSAA.
