Help karma ocean not working for me
2796 7 1-
- mzigaib
- 1030 posts
Hey I just trying to use the new Karma ocean directly from the shelf and it not working on Karma it is rendering flat but on Mantra is working fine.
I am using the apprendice version
Can someone point me what I can be doing wrong, I have attached a file.
Thanks in advance.
Thanks in advance.
Edited by mzigaib - Nov. 24, 2023 13:43:41
- dtempcyer
- 326 posts
- mzigaib
- 1030 posts
- mzigaib
- 1030 posts
- sniegockiszymon
- 71 posts
Use houdini preview procedural, this topic is well covered in this talk (I've used timestamp) https://youtu.be/R4SLw5EdzQ8?si=rw6dH5hSRHsWeI4r&t=1152 [youtu.be]
- dtempcyer
- 326 posts
mzigaib
Update:
If I render to Mplay it works which it kind makes sense since it is a procedural but how I can have a quick way to see it?
What would be a correctly workflow?
Would be nice if Sidefx could make a quick tutorial about this.
I also noticed that if you render with MPlay everything works, but to display in viewport you need to follow a certain sequence when connecting the nodes.
- mzigaib
- 1030 posts
Update:
I think I got it, I saw this on the presentation I guess.
You use the preview procedural to make quick renders on geometry which is controlled by a viewport quality ratio I think it does actually subdivide the geometry to be as close as the final result.
Edited by mzigaib - Nov. 24, 2023 17:22:54
- mzigaib
- 1030 posts
