latticefromvolume error
   1729   3   1
I'm trying to deform a pyro volume with a Lattice from Volume SOP.
However, it's throwing the following error:
Error
Invalid source /obj/AGB_Star_PromParts_pyro/latticefromvolume1/vdb1
Error: Either found no valid input VDBs, or found input VDBs with differing transforms..
At first I thought it might be data in the source pyro VDBs, I deleted everything except density.
I'm still getting the above error.
Please find attached a simple test hip file that loads this pyro volume:
https://drive.google.com/file/d/1M7ivGYWK9uKRvvfDLAMimnxm9kr04iH6/view?usp=sharing [drive.google.com]
What am I missing?
Edited by jlapre - Nov. 28, 2023 18:32:33
LatticeFromVolume_Error.v003.hipnc (159.9 KB)
Jeroen
your pyro cache contains houdini volume primitives, not VDBs
to convert to VDB you can use Convert VDB or Pyro Post Process SOP, ideally before caching, or check convert to VDB on Pyro Solver SOP/Output tab
tamte
I'll give that a try.
Jeroen
tamte
That worked! Many thanks, Tomas! 🙏🏽
Jeroen
