RunVex to access skel geometry?
2297 7 1-
- guilhermecasagrandi
- 288 posts
- kodra
- 373 posts
guilhermecasagrandi
Is the RunVex apex node suitable to run vex operations on the current (being animated) skel geometry? If so, how?
From what I've known so far, APEX doesn't have the concept of "currently being animated skel". You modify the skel with SetPointTransforms and other nodes, just like how you modify any other geo. You can have 1, 2, or 100 skel wired in. You can have a skel wired in but not animating it at all. When they say APEX is "All-Purpose" they literally mean it. APEX is arbitrary code.
So RunVex can operate on skel just like on other geo. However, you need to pay attention on where you put it (before or after SetPointTransforms, etc).
- 288 posts
kodraguilhermecasagrandi
that's the easy part, my question lies on the vex side, since vex functions don't expect geometry, but a path to a sop node, therefore I haven't found a way to use RunVex on geometry inside apex.
Nevertheless, I'm trying to find a way to run some kind of point cloud lookup inside apex, since there isn't a node on the geo tab for that.
- kodra
- 373 posts
- 288 posts
kodraThey are quite different, because a sop onde runs on geometry, but not vex code, that uses a path to a node to extract the geometry.
To be honest I haven't used RunVex either, I just assumed it works like sop::attribvop. sop::attribvop can run vex inside apex.
But as I said, what I'm trying to find is a feasible way to run some kind of point cloud lookup with apex. Any thoughts on that?
- tamte
- 9454 posts
- 288 posts
- 288 posts
tamteguilhermecasagrandiAnd sop::attribvop doesn't work for you? It should work exactly like wrangle in sops
Your suggestion did work, thanks, since attrib vop can run a snippet code.
