License administrator: "Invalid hostname provided"
   2361   3   3
Hi all,
I am currently trying to install Houdini 20 on Linux Mint 21.2, and all is well until I try to change the license server to the one provided by my school using the license administrator's add custom server function. Attached below is the error window which pops up.
I use Forticlient VPN to connect to their private network which hosts the license server, and using the
host <server>
command in CLI returns the correct internal IP-address, so this isn't a connection issue. Also, I know for a fact that the server works because I am able to activate Houdini without issues on Fedora 38 using the exact same method I described, only the Houdini version differs (19.5).
Am I missing something here?
Regards,
Victor
Edited by Vic_Fre - Dec. 9, 2023 13:29:28
Screenshot from 2023-12-09 18-27-06.png (13.1 KB)
Update: I tried the same for Houdini 20 on Windows 11, and the problem persists. Could this be an issue with Houdini 20?
Update: License Administrator 19.5 works fine, so we can confirm this is a Houdini 20 issue.
Edited by Vic_Fre - Dec. 10, 2023 10:55:43
Since there appears to be no direct solution to my problem, can someone tell me where in the filesystem the hostnames are stored? Maybe I can link the server manually.
Contact support if it used to work 19.5, then it's likely a regression in 20.0.
