Depth fading shader
   1704   2   0
Hi I am trying to find a way to make an opacity depth fade for my scene. My output is going to print and I need a way to provide the designers an easy way to fade the deeper parts of the image into a background color they provide.
- A depth AOV is great except it leaves a halo effect from the antialiasing.
- using rayimport (ray:hitdist) on the opacity of my Karma shaders gets close but I don't get a consistent opacity across different objects (see attachment).
Ultimately I would like to be able to avoid post processing an alpha into these images so I think applying a global distance fade seems the best idea. Would anyone have any suggestions for the best approach to this?
thanks
Jeff
Edited by jeffMc - Dec. 15, 2023 19:01:04
I am thinking I may need to limit ray refract depth somehow but only on the final image?
You can potentially use deep opacity maps, if you can comp it something that supports them, like Nuke or COPs
Edited by tamte - Dec. 15, 2023 19:23:53
