Object Merge drag+drop
   2069   3   2
In 19.5 it was possible to drag and drop an object from the Operator Tree into the Network View and it would automagically create an Object Merge SOP.
But this no longer seems to work in H 20.0.547, which is very unfortunate because it make merging multiple objects into a new Geo node so much easier.
Is there some secret trickery to make this work again, or can I add it to the list of broken features in H 20 ?
Thanks.
Still not fixed in 20.0.590 :-(
This is a functionality that is added by the ODtools plugin. So you need to install ODtools for H20 to make it work again.
It would be great to have all the ODtools drag and drop functionality as native Houdini behavior though.
Cheers
CYTE
Edited by CYTE - Feb. 21, 2024 05:56:39
Huh ? This used to work out of the box in 19.5 and ODtools is not free.
