Change pivot position of object at Geometry level?
   1259   2   1
Is it possible to move the transform handle of an object from its centre to its base at the Geometry level? I know how to do it at the Objects level.
If you mean setting the Handle of the Transform SOP to the Center of an object you can do it by using:
$CEX, $CEY, and $CEZ in the Pivot translate parameters.
Cheers
CYTE
I think the Copy to Points node ignores the Pivot Translate of a Transform node, so it seems I must use its Translate/Rotate parameters instead to reposition the copied objects.
Edited by litote - Feb. 19, 2024 19:08:25
