How to hide template view ?
   974   2   0
I have this Nodes setup : 10 grids with random direction and Noise to use as boolean cutter :
I use blast node to hide the other 9 grids and view only 1 grid to clearly see the noise :
Now when I want to edit the attribute noise nodes while viewing the blast . When I select the attribute noise ,the viewer looks very busy because it shows template of all grids :
How can I hide the template while selecting the attribute noise ?
those will only be seen in the viewport only if your geometry display is set to Show Current Operator and you have entered current node's state
- so you can hit Esc in the viewport to exit the state
- or click on empty network editor space to unselect the current node, you will still see it's paremeters
- you can also switch geometry display to Show Display Operator if you never want to see the state of the current operator
- or just move your Blast above the Noise node
Thanks a lot.
