Network Boxes not supported in USD and Edit Material Network
   1500   3   1
I got an issue with the writing out a .usd material and the Edit Material Network" node. Is there a way to for USD / Edit Material Network node to recognize the network boxes and placement of nodes within the nodegraph? Is there a future plan to support this?
Here is the original network with the network box:
Here is the .usda file read in again and viewed through an "Edit Material Network" node:
Edit Material Network re-constructs the shader network from USD primitives. And the USD shader primitive network does not encode the network boxes.
P.s., There is a concept of UsdUIBackdrop, but the shader translators don't make use of it yet.
Thanks, got it.
Is support for UsdUIBackdrop coming? Is that Houdini itself that will need to support this or the third party renderers?
Eventually yes, Houdini will utilize the UsdUIBackdrop but there are higher priorities at the moment. Houdini will need to do it for Karma and MaterialX builders. The 3rd party renderers will need to author them in their custom shader translators. And Houdini's Edit Material Network will need to recognize them for all renderers.
