Falling particles problem with FLIP narrow band
   1896   1   1
i am trying to use narrow band feature in flip solver. Everything works fine when i am not changing center of volume limits or water level in oceansource. But when i want to set bottom of volume limits in 0 on Y and water level in the middle of Y size it doesn't work. Waterline particles just falling like there are nothing beetween. Do you have any idea why this is happening? Is this a bug or am I doing something wrong?
I am attaching files with my setup in the post.
Thanks,
Dawid
Edited by Dawid Wizor - April 15, 2024 11:44:25
flip_narrow_band.hiplc (707.8 KB)
Dawid Wizor
Thanks,
Dawid
If you go to the ocean source node and go to surface evaluation and set it to flat it should work. I would recommend using the shelf tool presets to learn how to set this stuff up.
Edited by evanrudefx - April 16, 2024 17:31:20
Thanks,
Evan
