I have an Educational license and want to make an Ocean. When I save the displacement maps it saves with the extension ".picnc"
When I load this sequence in RS textureand render I get an error:
"Texture Processor failed for ....picnc'! 'OpenImageIO could not find a format reader for ....0001.picnc".
I understand that "nc" at the end of the sufix stands for "non commercial". Then I used Mplayer to save the sequence as ".EXR".
And when I load the texture sequence I am getting this "!" in the RS Texture node:
Warning Cannot have channels which depend on time. "
Is all this an "Educational License" issue? Is a RS issue? Is there a way to solve this?
.picnc sequence of images
1093 2 0-
- Fernando_Criativo3d
- 9 posts
- Enivob
- 2658 posts
Not loading a sequence is a Houdini vex compile issue. You can't embedd $F4 into a file name inside a subnet. What you can do is head up one level and alter the interface to include a file name and browse to your sequence there. Right-Click to Copy, then dive inside the subnet and paste the relative reference into your texture node's filename field.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- 9 posts
EnivobThanks, I will try that.
