Determining on which object SOP Solver operates in DOP
   945   1   2
i have setup with two RBD packedobjects containers in DOPs. Is there any way to choose for which of these objects the SOP Solver should work?
Thanks,
Dawid
Edited by Dawid Wizor - Aug. 12, 2024 08:06:01
The Switch Solver comes in handy for that. Here's an example using Switch Value DOPs to set the data value that will be picked up by the Switch Solver DOP which will only enable a particular branch to be run per object.
SwitchSolvers.hip (304.8 KB)
