Hey, I'm really struggling with compositing in ACES 1.3
I have a beautiful jewelry shot as part of an animation, which I need to comp over an sRGB .jpg backplate.
ACES 1.3 for Nuke & DaVinci require me to apply a "inverse display transform" (see screenshot) to get sRGB files to display and behave correctly.
But for some reason I just can't find this option or an equivalent in COPs.
The "OCIO transform" node doesn't seem to have any option for this at all.
And only seems to work with ACES 1.2 -- where the Original Space can be set to "Output - sRGB". And then To Space: "ACES - ACEScg" (see ACES 1.2 screenshot in Houdini 20.5.332)
How is this supposed to work in Houdini under ACES 1.3 or where did they hide the "inverse display transform" options which are required in other compositing software to make this work?
Thanks for your time and help, I really appreciate it.
Edit: This is solved and the "OCIO transform" node now has an "Invert Transform" checkbox. Hope this helps.
COPs invert ACES 1.3 to work with sRGB correctly (solved)
2151 4 3-
- Yannik
- 24 posts
- wanglifu
- 222 posts
- mikaellundin
- 1 posts
- jsmack
- 8177 posts
- Yannik
- 24 posts
Hey, just to update and close this.
The new versions of Houdini now have an "Invert Transform" checkbox in the "OCIO transform" node, which allows us to do this correctly
I have just used this with ACES 2.0 (cg-config-v3.0.0_aces-v2.0_ocio-v2.4.ocio) and can confirm that this works as intended.
Edited by Yannik - Dec. 4, 2025 14:57:28
