Hey there,
I am building a scene from assets I created for a vr experience last year and I would like to use those textures in Karma XPU. In Unity it is common practice to combine the albedo and roughness for non metal materials. Roughness being stored in the alpha channel.
It seems that the rgb channels are influenced by the alpha channel though. Even after separation. This can be proven by using two different textures wich give the correct result.
If this is no bug, what am I doing wrong?
MtlX Image Color 4 Separation Bug? Use roughness in alpha ch
1707 5 1-
- Kareeem
- 100 posts
- Kareeem
- 100 posts
- jsmack
- 8177 posts
Kareeem
Further testing showed that even if I set the MtlX Image node back to its default Signature "Color" the final result is incorrect if the albedo texture has an alpha channel. It seems that the alpha channel gets multiplied onto the rgb information.
are you using a png by chance? PNGs are problematic as their spec says to premultiply the color by the alpha channel, but all the realtime applications that use PNG ignore the spec. Houdini's OIIO library always follows the spec for pngs, however there is an environment variable that can control how they are read by the OIIO library. I would recommend avoiding PNGs entirely and using EXR or RAT files for all textures as this avoids the ambiguity of the format.
- Kareeem
- 100 posts
jsmack
Thanks for taking the time!
I am indeed using png files and am also not familiar with OIIO library.
Houdini automatically creates .rat files when I link a png file. I´ll have to check for a batch conversion process from png to exr then...
I wouldnt know how to change that environment variable but it also doesnt feel right to make a global change for this issue. Although it is quite annoying since many textures I have from other projects are in png.
Edited by Kareeem - Sept. 6, 2024 12:38:28
- jsmack
- 8177 posts
Kareeemjsmack
be careful what you use for batch conversion, as most tools will treat png as 'unpremultiplied' and subsequently apply the alpha to the color data.
I use this in my houdini.env to allow for use of pngs as textures without corruption:
OPENIMAGEIO_IMAGECACHE_OPTIONS="unassociatedalpha=1"
a file COP can be used to load png file and force the color to load unpremultiplied (when using the old COP2, I haven't seen if the option still exists for Copernicus)
- Kareeem
- 100 posts
jsmack
Yeah, I couldnt find any good conversion method quickly, so i grinded through the textures manually.
So you're using environment variable as well. Thats comforting to know.
I will test this and report back.
Thanks again!
