About Houdini timeshift node
831 1 1-
- yunni
- 1 posts
- tamte
- 9303 posts
The frame in timeshift is the frame at which you want to evaluate the input geometry
So if you want the frame 1 to start at 21 then you need to use $F-20
Since then when you are at frame 21 it will evaluate the frame 1 (21-20) of your input geo
You can also use Retime SOP to do some common time manipulation like in your case Shift Range
