Vellum Grain: kill particles below height?
   1485   4   1
Hi!
I'm starting to learn Vellum Grain and I would like to know how to kill or freeze partciles that goes below a certain height. My collision ground is not very wide causing many particles to spill to the sides (out of camera view).
-Olviier
Hello! You can create a pop kill and plug it in the source output inside the Vellum solver. Then either use the bounding tab or the rule tab with
dead = @P.y < 0
or whatever your height is.
Hi Tanto!
hmm... when I dive inside the Vellum Solver, I can't create a "pop kill" node. In fact, I almost have not nodes I can create. Could it be because I'm using Houdini Core?
-Olivier
Yes, that is the reason unfortunately. To be honest I'm not too sure how you would do it in Core.
Ok, thanks for the info!
