filename substitution in materialx
   1055   1   0
On page 18 of the materialx spec (https://materialx.org/assets/MaterialX.v1.38.Spec.pdf), it says filename substitutions can be made using <geometry tokens> / <geominfo> elements. Is this possible in Houdini?
In the newest specification, it now says "Applications using USD for geometry and assignments may additionally use a <geometry token> (a.k.a. "<primvarname>") as the entire filename string to access an entire string primvar value unchanged." So, very similar, but specifying USD "primvars" instead of "geominfo".
Link to quote: https://github.com/AcademySoftwareFoundation/MaterialX/blob/main/documents/Specification/MaterialX.Specification.md#:~:text=fully%2Devaluated%20filenames.-,Applications,-using%20USD%20for
Are either of these possible using USD/ MaterialX in Houdini? Or something similar, specifically, to control the filename input of an image node from the geometry.
This could also be achieved with the new GeomPropValueUniform node which was added to materialx last month. Is there a timeline yet for when this could be added to houdini?
Link: https://github.com/AcademySoftwareFoundation/MaterialX/commit/81ed31d43026cc0e475bbdf9b040ccbc17ba60bc [github.com]
So far, I've achieved it using a float primvar to control a switch of images, and UDIM substitutions, but I'd like a cleaner approach to the problem. Thanks in a advance for any suggestions!
Edited by vrbn studios - Jan. 17, 2025 04:39:33
vrbn studios
GeomPropValueUniform will be available in the next version of Houdini.
