Get Array of all Folder Names in specific path(VEX? Python?)
   912   3   0
Hi!
I have a folder containing each individual assets for a project. Each asset is in a folder and I would like a way to generate an array of all folder names in VEX if possible.
I would prefere a VEX solution since that's the only coding I know. If not, Python.
-Olivier
I think Vex can't interact with the file system. You could use Python to make a list of folders and then set them as a detail array attribute on your geometry, so you can then continue in Vex.
If you're in sops, you can drop down a Python sop:
import os
node = hou.pwd()
geo = node.geometry()
# Set this variable to your path
source_dir = "$HIP/USD/Kitchen_set/assets"
# Finds directories in source_dir
dir_list = [filename for filename in os.listdir(source_dir) if os.path.isdir(os.path.join(source_dir,filename))]
# Adds and sets detail array attribute named "assets"
array_name = "assets"
geo.addArrayAttrib(hou.attribType.Global, array_name, hou.attribData.String)
geo.setGlobalAttribValue(array_name, dir_list)
You should now see an array attribute containing the names of folders present in the specified directory.
Depending on your setup, maybe File Pattern TOP could be an alternative solution.
I just realized you were most likely asking about Solaris Vex/Python. My bad. Here's how you could handle it using Python Scrip lop:
import os
from pxr import Sdf
node = hou.pwd()
stage = node.editableStage()
# prim to store the array on
prim = stage.GetPrimAtPath("/cube1")
# Adds and sets array attribute named "assets"
attr = prim.CreateAttribute(array_name, Sdf.ValueTypeNames.StringArray)
attr.Set(dir_list)
Ah, super! Thanks a lot. I'll test that out.
Thank you for your time!
-Olivier
Edited by olivierth - Feb. 17, 2025 14:37:00
