GasOpenCl: use a soond input or other geometry
   845   1   1
Hello
I need to control a mpm with some additional geometry to control the effect. it works fine with a wrangle but it is slow.
I tried to port it to a gas opencl, but I can not see a way to import a second geometry, like in the new opencl sop, that has 4 inputs ports or a wrangle DOP that also has additional inputs.
is there a way to do this with the gasopencl dop node?
Martin
I solved it with a sopsolver that stores the activation frame on the geometry, so the points know when to start, and the gasopencl was simple, no need for extra geometry
but still would be interested if this is possible at all. I hope at some point the gasopencl dop is like the sop version
Martin
