kinefx - mechanical rigging - offset ?
1103
3
1
w_maro
Feb. 26, 2025 8:04 a.m.
hi
- did this little setup to test mechanical rigging
setup works fine
but the bonedeform offset the inputgeo
- so I have to rotate the inputgeo to correct the offset?
(in 3dsMAX there is a "keep inital offset") is there somthing similar in houdini ?
or is there better way to set this up ?
Edited by w_maro - Feb. 26, 2025 08:06:06
kinefx_rig_piston_01-stash.hiplc (711.4 KB)
CYTE
Feb. 26, 2025 1:08 p.m.
In your rigaatribvops use the "look at constraint" node not the "look at(kinefx)" one. it has an "Update offset" button. Cheers CYTE
Edited by CYTE - Feb. 26, 2025 13:08:53
w_maro
Feb. 28, 2025 2:51 a.m.
thanks alot for your feedback
thats exacty what I was missing
for anyone interrested in the setup
here is the hip file
kinefx_rig_piston_01-fix_stash.hiplc (737.8 KB)
Mike_A
Feb. 28, 2025 11:48 a.m.
Thanks for sharing this! I think there are quite a few of us that would like to see more mechanical rigging examples, so take that as encouragement to keep the discussion going : )
