Creating a Simple Screw
51205 22 2-
- Lyonz
- 114 posts
Hi all i was wondering if anyone had a good way to model a screw as im beat.
This is what i have done so far:
http://i23.photobucket.com/albums/b395/1davidlyon/Screw.jpg [i23.photobucket.com]
I have used a curve and snapped the points to the grid then used a revolve to get a 360 model.
I am wondering if there is a HELIX shape or option in houdini like 3ds max has ? If someone knows how to create a simple spring that would do.
This is the kinda method i used in 3ds max:
http://www.freeitsolutions.com/3ds/viewTutorial.aspx?id=3380 [freeitsolutions.com]
- mark
- 2686 posts
- Lyonz
- 114 posts
- edward
- 8154 posts
- Lyonz
- 114 posts
edward
Try searching on odforce.net … I vaguely recall someone putting up an example.
Ive had a look on odforce and couldnt find an example would someone be able to break down how the file above was created ? as i get errors when reconstructing it …
The error i get is bad parameter reference “../turns” in parameter /object / circle_object2/circle1/divs
The error i get is bad parameter reference “../quality” in parameter /object / circle_object2/circle1/divs
- ragupasta
- 349 posts
- ragupasta
- 349 posts
- Lyonz
- 114 posts
- jacob clark
- 665 posts
- Lyonz
- 114 posts
jacob clark
Hi Guys,
Another great trick…
Try using the twist SOP on a highly subdivided box.
Maybe not the most elegant, but damn, if it doesn't look like a screw to me!
cheers,
-j
Yea i tried this at first and gets you a great result if your after a ground drill like this.
http://www.tradevv.com/TradevvImage/productimages/Ground-drill-A5ba18.jpg [tradevv.com]
- old_school
- 2540 posts
ok here's my attempt at a screw. Lag bolt more like it. I like the profile approach as opposed to the old school make-a-corkscrew-then-pound-the-crap-out-of-it way.
Hopefully the cookie (boolean) operations hold up…
I am sure that there are procedural ways to better fuse up the shaft to the thread and better work on the tip. It's just lining up your ducks.
As well I eyeballed the copy SOP to align the sweep of the profiles but I am sure you can get simple math in there to do real thread pitch standards.
- Anonymous
- 678 posts
This is what I came up. It's not ready yet, many parameters are missing or need to be rewired but it's a good start. Not faraway from full working procedural.
Below you can find HIP file and OTL for DOWNLOAD:
http://www.4shared.com/file/149824982/e2bb698b/screw.html [4shared.com]
http://www.4shared.com/file/149826584/a8cbfd51/Screw_OTL.html [4shared.com]
- old_school
- 2540 posts
- AndersBP
- 12 posts
- Lyonz
- 114 posts
- Anonymous
- 678 posts
- Lyonz
- 114 posts
- Anonymous
- 678 posts
- Lyonz
- 114 posts
- matthias_k
- 483 posts
I know the question was: How to model a screw :-)
But hopefully this is helpy, too. If it's not necessary to have the real geometry, maybe a simple displacement shader can do the work.
This solution gives more flexibility and can bring a cleaner look without having “big” models. If you get “artefacts” in the rendering, make sure “Predicng” is set in the SOPs render settings.
