Head model
   14440   23   3
Submitted it to the database
Werner Ziemerink
Head of 3D
www.luma.co.za
Werner Ziemerink
harryabreu
Werner Ziemerink
Werner Ziemerink
Hi Mr Werner Ziemerink.
My name is Harry Abreu and I start Houdini few weeks ago.
I'm sorry to boring you on this tread.
I'm tried to use Houdini for modeling but probably I'm doing some thing wrong after I tried to find answer I had no luck if possible can you see my question on this other forum to give me a little help?
Thank you very much.
My question [sidefx.com]
Hi harryabreu,
I've experienced the same issue with 15.5 when it comes to slapping down edgeloops and PolySplits. These tools has been re-written from scratch and are bound to be a bit buggy.
Your video shows this problem very well and I will submit a bug if you don't mind using the video as reference.
OK let's go if you and me show the same problem we can help Sidefx to improve Houdini for a lot of people ;-)
Werner Ziemerink
pusat
Very impressive work
Btw I wrote a Slide Edges tool a while ago:
Do I have to create a group of my selection before I ad the Slide Edges node. It does not seem to remember my selection from an edit node selection?
I made a mistake on the animated GIF. It should read “Proportional Slide OFF, or ON”
Hey man sorry I didn't see this but if you have a group it's easier. I might have to add some stuff to allow auto populating the Group field I think.
Thanks Pusat, but the current built edge slide works fine. The L hotkey makes for quick editing.
Werner Ziemerink
Head of 3D
www.luma.co.za
