Hi there,
I'm embarrassed to ask this question but I am having trouble poly extruding a line…
It seems to work with a curve but the line node doesn't. I was expecting it to make a poly like this -
I can work around it but it is hurting me not knowing why I can't get it to work.
Any ideas?
Thanks,
Pete
Poly extruding a line. (Yes you read it right)
6588 6 5- peteski
- 517 posts
- mestela
- 1743 posts
- peteski
- 517 posts
- grayOlorin
- 1799 posts
- amberija
- Aizatulin
- 477 posts
it works for me (18.5.408), if you choose for extrusion mode (point normal and attribute), where the attribute should be a point vector attribute, which defines the direction. You can also change the length and it will effect distance. The orientation along curve will automatically give you v@up attribute.
- amberija
AizatulinThanks, that's huge. But I was looking for a simpler solution. Usual DCC has a straight forward way of achieving just extruded spline. I think polyextrude with translate makes it more accessible. But thank you anyway!
