expression in file path
5545 6 1- X_H_N
- 31 posts
- 8555 posts
- Manuloti
- 26 posts
Hello, I'd like to ask something along this same line. May you can help me out in this case too.
So my situation is the following:
I'm trying to feed a number of pre-made curves into a File node. In order to do so, I thought I could build a string array in an attribute (detail) wrangle, with the paths to the .ai files, and then extract each file path by feeding a chi to select each array item. So far so good.
What I've noticed is that File nodes don't store data. Is that correct? I connected the attrib wrangle and I couldn't see any attributes (I tested on other node in case was a coding mistake, but they worked fine). So... that's when I land in this same question of how to import data in the file path of a File node (Geometry File is the name).
I attach 2 snapshots. One with the mentioned nodes,a second one with the the array (I've only included one file path xD, just testing) and a last one with the error showed in the File node.
I tried adding the "`"
"to_feed" is the attribute wrangle
"ref_string" the attribute
"0" as... I'm retriving the the index = 0 of the array? That one I don't have it clear
Anyways, doesn't work : /
Is there a way to make it work? Can I retrieve a non-connected attribute into a File node geo path?
Alternatives?
Thanks in advance!
`detail("op:../to_feed", "ref_string", 0)`
Alternatives?
Thanks in advance!
- 8555 posts
for strings you have to use details() [www.sidefx.com] function as in the example or in the help
also no op:necessary as detail/details hscript functions are expecting path to sop node directly
so yours would be something like
`details("../to_feed", "ref_string")`
Edited by tamte - 2022年3月30日 15:33:39
- Manuloti
- 26 posts
Ohhh, so it was "details()" not "detail()" for string values. This should make me remember it : ).
About the "op:" call... I might have get an error (and read the doc in consequence) several times more in order to guess, more or less, when it's required.
Anyhow, problem fixed. I don't know if I can @tamte here, but I do it anyway in order to thank you.
Best.
Best.
- 7771 posts
- 8555 posts
it may definitely be confusing as detail()/details() expression function and detail() VEX function are a little different
expression version expects operator path (or input index)
VEX version expects geometry as filepath on disk (or input index) so as jmack said that one needs op: hint to interpret it as operator path
so its very likely you were reading the docs for VEX version
