Empty or Missing file path
   9627   18   3
Hello, I'm doing the https://www.sidefx.com/tutorials/create-a-task-workflow-to-build-cities/ [www.sidefx.com] tutorial and I have a problem in the part05 section 2. In the “geometry import” node, I have the following errors.
I've redone every steps multiple times and still get the same errors.
Thank you
Edited by RonanCroyal - 2019年9月22日 11:36:35
Hi Ronan, could you post the file?
- Ken Xu
Here it is ! Thank you.
Edited by RonanCroyal - 2019年9月26日 12:21:22
tops_lesson_start.zip (1.8 MB)
Hi Ronan, which version of Houdini are you currently using?
The latest, 17.5.389. I've tried on four different 17.5 build but always the same error.
I just tried 17.5.389, and had no issues cooking Building_Merge.
If you go to Tasks>Dirty All, then select Building_Merge and go to Tasks>Dirty and Cook Selected Node, do you still get the error?
Which operating system are you using?
Edited by johnmather - 2019年9月26日 13:34:05
Still the same error.
By any chance do you have multiple drives on your machine? Are your projects stored on another drive other than C:\?
Yes ! My project is not stored in C:\
Edit: I've moved the project to c:\ but still the same error.
Edited by RonanCroyal - 2019年9月26日 14:18:35
Did you set your project like in the tutorial?
Yes.
I've redone the tutorial, with the file set to the project like before, but this time in C:\, and always the same error.
Could you please attach a screenshot of the work item attributes? You can access this by CTRL+MMB clicking the work item in the Wait for All node.
Are there any file paths in that window?
Sorry but I'm not sure what you mean. There is nothing more at the bottom of the window, if this what you mean !
Ok. Are any files actually being written to disk?
Yes
Hi Ronan,
Could you please attach a screenshot of one of the ROP geometry work items, as well as attach the log PDG log files? Your scheduler node will show the temp directory where the log directory is located.
PDG_LogFolder [www.amazon.fr]
