Are there any tutorials/documentation how to get (render) an image from hydra delegates(renderman/redshift/pro-render)?
I understand that I have to render scene from “stage or lop network” with usd render render node but had no luck with that with 3rd party engines(karma works just fine).
[solved] USD render with 3rd party engines
7497 11 1-
- brokenkeyframe
- 57 posts
- RonanCroyal
- 31 posts
- brokenkeyframe
- 57 posts
Thank you! But for example, RenderMan just renders forever in my case.
In previous 22.6 it was a checkbox, to disable incremental rendering, but I can't find that anywhere here. I bet 100% I will post this message and will be able to find it
Anyway, just in case I won't, can you please share the tip on this one too?
Edited by brokenkeyframe - 2019年12月4日 10:57:08
- RonanCroyal
- 31 posts
- brokenkeyframe
- 57 posts
Changing integrator doesn't help. Even if I select “PxrVisualizer” it renders instantly in the viewport but doesn't render to the image. And for example, if I select frame range it just starts to render forever but nothing is rendered. Although that extra heat that comes from pc while rendering imaginary seq files on this winter day - can't complain.
- RonanCroyal
- 31 posts
- brokenkeyframe
- 57 posts
- 8192 posts
- Siavash Tehrani
- 737 posts
brokenkeyframe
I think it's a bug I'm having. Looks like I can render images 1280x720!!! If I render 1920x1080 or bigger ones, it renders image somewhere, but it doesn't save the image to the disk. Thank you for your previous tip, it is the way of doing it!
It's a licensing issue like jsmack said. I'm getting watermarks in Karma and Redshift and my Karma renders also fail if I go above 1280x720. The devs are working on it.
- brokenkeyframe
- 57 posts
- stevenshook
- 15 posts
- 8192 posts
