Houdini Data Interface for UE4's Niagara
50754 38 20- NotSure
- 33 posts
- Leopik
- 3 posts
Hallo Mike,
could you please explane more to detail about how to export niagara destruction with pyro sim to UE4.
I am quite new in Houdini, I finished my first Sim and now struggle with export to UE4.
I follow your video instruction but I dont know how did you setup?
https://vimeo.com/276129739/5aa8e05a88 [vimeo.com] - Niagara ROP walkthrough.
Thank you for your great work and sorry for vaste your time.
- mikelyndon-sesi
- 394 posts
- Leopik
- 3 posts
Thank you for very fast reply.
I am very new in Houdini and just did not get it which dopnet node I should connect to niagara rop? I dave one with destruction, one with particles and one with pyro sim.
I would like to move all my destruction to UE4 as you did in your video https://vimeo.com/286182503 [vimeo.com]
Maybe my question is very stupid, but I really did not get that.
Thank you for your great work and patience with me.
- mikelyndon-sesi
- 394 posts
- Leopik
- 3 posts
Wou,
Thank you Mike … sometimes I need some push with right information and you just did it. Thank you so much …. I thought it is possible to export all in one single node.
So far I exported destruction with fbx and that is working great in UE4. So now I have next task, …. it is so helpful …. sincerely I appreciate
- localstarlight
- 45 posts
I had been hoping to use the Houdini -> Niagara workflow to bring in a particle (whitewater) sim into Unreal, but I'm starting to get the sense that might not be possible with this system?
Does this only work with a set number of particles? Whitewater has varying numbers of particles per frame (though each one has an id).
I want to bring the ids and positions over time into Niagara and use them to spawn bubble meshes as the particles (not doing anything with foam or spray, just a few hundred bubbles).
The Niagara ROP doesn't seem set up for this, it seems like it's only for RBD sims, or am I misunderstanding something?
Is there a way to do this?
- mikelyndon-sesi
- 394 posts
- kuimig
- 16 posts
Hi mike!
1. houdini hcsv data import Niagara Cpu sim is OK, but when switch to GPU sim the particle.it disappears.
2. What's the trick to import a large number of particles into UE4? VAT? Or currently, Niagara GPU solution is not supported?
I exported CSV particle import data into UE4 in Houdini and compared it with VAT data input into UE4. A large amount of VAT particle data enters UE4 and runs faster, but the POS map data will be very large. After CSV is imported into UE4, the operation will be delayed with Niagara Runs slowly even if there are not many particles
- joshua.batty
Hi there, firstly wanted to say thank you for such an awesome tool. I'm really loving the potential workflow this offers.
I am trying to find the .cpp files in the Private folder but they don't seem to be included with the plugin, only the Public folder .h files. Is there a github page where the development of the plugin is taking place that I might be able to take a look at?
for example, where can I find the HoudiniCSVFactory.cpp or the HoudiniCSV.cpp file for example? I want to build my own custom data interface for Niagara in C++. Being able to study how this plugin was implemented would be a great help as there really isn't much documentation on how to go about it online.
- joshua.batty
- mikelyndon-sesi
- 394 posts
kuimigHi kuimig. This is a known issue. We're working on a fix at the moment. We should have an update in the next month or so.
Hi mike!
kuimigFor now, I would suggest using VAT. We have plans to improve performance with large data sets but I can't give you an ETA on when that will be available.
- Wings999
- mikelyndon-sesi
- 394 posts
- dunenkoff
- mikelyndon-sesi
- 394 posts
Please refer to this thread for all future updates.
https://www.sidefx.com/forum/topic/73075/ [www.sidefx.com]
- rafaelzz
kuimigHi mike!Hi kuimig. This is a known issue. We're working on a fix at the moment. We should have an update in the next month or so.
Hi Mike, has this been fixed in the latest 521 SideFX Labs build? Or should we just stick to VAT data in order to use GPU in UE 4.25.1 Niagara? CPU-only for Houdini sims make the whole plugin unusable for me.
- flix_ujin
- 4 posts
Hi Guys,
I am trying to package my game in UE4 with houdini niagra actor on it but I always got an error that says:
UATHelper: Packaging (Windows (64-bit)): ERROR: Missing precompiled manifest for ‘HoudiniNiagara’. This module was most likely not flagged for being included in a precompiled build - set ‘PrecompileForTargets = PrecompileTargetsType.Any;’ in HoudiniNiagara.build.cs to override.
I have followed the installation video tutorial exactly the same way.
For specification:
I am on Windows 10 64bit and running Unreal Engine 4.25.3
Could someone please help me how to fix issue?
Thank you in advanced!
For specification:
- lexlegs
