how to add bump image to material x
   10099   6   2
Hi.
If I had a standard grey scale image (noise), how do I plug that into material X standard surface to get bump working. I have treid a few things but am unsure.
Thanks in advance! Best
bump.hipnc (124.7 KB)
A greyscale image is not the same as a Normal map, those look purply. I'm not sure if Karma supports actual bump mapping yet, but you can use a greyscale image for displacement. You have to "collect" up two shaders to combine them, and assign the collected node to your object as the material.
ap_bump.hipnc (800.0 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Hi. Thanks. I did think of using a disp map. The other thing I was thinking was if I could convert a bump to a normal in the shader network somehow.
Best
I don't know if you can use the old bump to normal vop within materialX (it would be KarmaCPU only, since XPU doesn't do vex), I tried it for a minute and wasn't able to.
But.. if it doesn't have to be explicitly "in" the shader network, you could go through cops and use a vopcop filter with bump_to_normal to generate the normal map from your bump. That works.
Give him the stick, DON'T GIVE HIM THE STICK!
Would the mtlx height to normal be any good?
https://www.sidefx.com/docs/houdini/nodes/vop/mtlxheighttonormal [www.sidefx.com]
Hi Ben
Yes!. It worked!. Thanks. Mark
オンライン
how would u add float bump map to a normal map?
https://www.youtube.com/channel/UC4NQi8wpYUbR9wLolfHrZVA [www.youtube.com]
