Karma Motion Blur way to strong / weird
2662 7 0- chf
- 156 posts
I am rendering an old project which used to use redshift with Karma.
I have a simple rbd sim and then transform hires onto the proxies including velocity from the sim.
Karma just messes up the motion blur. Is this a (current) limitation or a bug?
The 4 images are:
no motion blur CPU
no motion blur XPU
with motion blur CPU
with motion blur XPU
lighting looks different, but thats something I can work
the big problem in both is the weird looking motion blur
The 4 images are:
no motion blur CPU
no motion blur XPU
Edited by chf - 2022年1月13日 06:09:33
- Enivob
- 2539 posts
- chf
- 156 posts
it seems to be related to them being packed primitives and also the fact that I am randomly deleting those packed points through the sequence, which leads to point numbers flipping around and karma seems to be confused by that
after i used an unpack node it it worked fine, but way slower of course
also for some reason motion blur on packed just completely fails to render, just wont any more
I guess this may be some bug / graphics driver issue because optix also failed and then crashed
KarmaXPU: device Type:Optix ID:0 has registered a critical error , so will now stop functioning. Future error messages will be suppressed
will test further
will test further
Edited by chf - 2022年1月13日 11:05:19
- mark
- 2593 posts
- chf
- 156 posts
mark
It almost looks like the topology might be changing frame to frame. Are you using velocity blur?
I am using velocity blur. But it doesn't work on packed primitives.
Made a quick setup to sandbox the issue.
No matter what I do, Motion blur only works if I unpack the transformed geometry before importing it into solaris/karma world.
- mark
- 2593 posts
chfUsd expects the velocity primvar to be named
velocities
. If you stick an Attribute Rename SOP before /obj/karma_test/output0
, the instance will pick up velocity properly and you should see motion blur. This is not obvious at all. It took a bit of debugging on my end to actually track this down.The other thing which I see you attempted was to use "Unpack" in
/stage/sopimport1
. This uncovered a bug in Karma. This should be fixed in tomorrow's daily build. So leaving the v
attribute alone, but choosing Unpack in the SOP import should work in tomorrow's build.
- 8583 posts
mark
Usd expects the velocity primvar to be named velocities. If you stick an Attribute Rename SOP before /obj/karma_test/output0, the instance will pick up velocity properly and you should see motion blur. This is not obvious at all. It took a bit of debugging on my end to actually track this down.
does it support angular velocities?
since those are important on packed primitives
I tried renaming w to angularVelocities, not sure if that's correct property on regular prims, but also didn't seem to do anything
- chf
- 156 posts
markchfUsd expects the velocity primvar to be named
No matter what I do, Motion blur only works if I unpack the transformed geometry before importing it into solaris/karma world.velocities
. If you stick an Attribute Rename SOP before/obj/karma_test/output0
The other thing which I see you attempted was to use "Unpack" in/stage/sopimport1
. This uncovered a bug in Karma. This should be fixed in tomorrow's daily build. So leaving thev
that's fantastic thank you so much!
