The downloaded geometry has many inverse normal parts(like the ex. pig image).
How to select them rapidly?
How to select back face only?
7414 6 2-
- jerry7
- 681 posts
- CYTE
- 805 posts
- malexander
- 5307 posts
- 9538 posts
malexanderthis doesn't seem to be compatible with Select Visible Geometry Only, which would be required for the task of easily selecting problematic faces manually
In the select tool's RMB menu, there's an option to select back faces only.
Select Back Facing Only on its own correctly select back facing, however for models like in OP, some backfaces are visible, and those are intended to be selected, but on the other side of the model there are backfaces that are not intended to be selected as they are supposed to be backfaces from this POV but are also invisible (occluded)
but turning on Select Visible Geometry Only seems to select all visible primitives front/back facing, seemingly ignoring Select Back Facing Only
Edited by tamte - 2023年1月7日 22:09:28
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- toonafish
- 583 posts
- Gagui
- 58 posts
- CYTE
- 805 posts
