Hi
In the whats new: https://www.sidefx.com/docs/houdini20.0/news/20/karma.html [www.sidefx.com]
I should be able to get Karma to auto see any custom AOV's I have made in Material Builder. I am a little stuck on how to do this however. Has anyone tried this and got it to work? Best. Mark
EDIT: This seems to be a bug I have logged it under Bug #132803
H20 Karma Auto AOV. How to
986 3 1- Mark Wallman
- 647 posts
- Luxor95
In fact, there is a problem with it, I only work as a float and later I change to vector. However, if I refresh the aov, for example by attaching a new one, the old aov that is already a vector disappears. The only option at the moment is to connect all AOVs as floats and then change their inputs to correct ones.
- 7771 posts
Luxor95
You don't need to add aov exports to the shader for primvars, simply add them to the render settings render var section by selecting primvar as the source.
- Luxor95
