Transforming a lissajous curve along a given input curve
1163 12 1- createdbybenm
- 6 posts
Hello everyone,
I want to create braids in Houdini and found this paper from Pixar (https://graphics.pixar.com/library/Cornrows/paper.pdf) in wich they shared a formular to create the braids.
I managed to get the x and y coordinates working as I basically had to copy the function into VEX but now I struggle with getting the z coordinate. I tried several things but I am either a math nor a VEX expert so every help would be gratly appreciated!
As I mentioned I have the lissajous curve but with my solution the rotation along the input curve seems off and everything is still two dimensional.
- Aizatulin
- 480 posts
- Mike_A
- 185 posts
- createdbybenm
- 6 posts
First of all thank you very much for your replies!
I tried it with the curve deform but it is not working. I think it is because of the lassajous curve still being two dimensional and not already extruded along a line which than can be deformed by the path deform.
Maybe there is a way to do this in VEX with quaternions probabily because everything is dependant on the input parameters and even if the path deform would work somehow I guess it would not hold up in the long run.
Anyways thank you for investing your time in my problem!
Here is what I did and where I am at:
- Aizatulin
- 480 posts
- createdbybenm
- 6 posts
- Aizatulin
- 480 posts
- createdbybenm
- 6 posts
Hey everyone,
so I have been working on this for the last days and I managed to deform the lissajous curve along the input curve via orthonormal frames (all in VEX) but now I ran into another problem.
It seems like the input curve is devided into segments resulting from its control points (although the curve has been resampled) which leads to seemingly different frequencies.
If anyone could help it would be gratly appreciated I am running against a wall here.
- animatrix_
- 4531 posts
Your curveu is not computed correctly by the Resample SOP. Add another Resample node after the first one without resampling but to compute curveu only:
- createdbybenm
- 6 posts
- animatrix_
- 4531 posts
createdbybenm
Oh wow that was an easy fix.
Thank you so much!
Small question how did you overlay your viewport over your nodes seems very efficient in terms of space usage?
It's a custom Python Qt extension:
You can see it in more detail here (around 30 min mark):
If you like to see this added to Houdini, please submit an RFE to SESI and reference RFE ID #101685.
- createdbybenm
- 6 posts
- animatrix_
- 4531 posts
createdbybenm
I would love to see this in vanilla Houdini but I'm sorry I dond't know what you mean with rfe and sesi?
I meant submitting a feature request here:
https://www.sidefx.com/bugs/#/create/ [www.sidefx.com]
That's how SideFX (SESI) collects bugs and requests for enhancements (RFEs).
