I'm stumped on this one.
I ctrl-click Box to make a box at the origin.
I make sure the camera icon is selected on the left & the box is still active.
I press either shift + on my keyboard or the numeric keypad + key to turn on “View selected objects as subdivision”.
I get a message in the main window saying “Turn On Viewport Subdivision”.
Nothing happens.
I went in and renamed my houdini16.5 folder in Documents to houdini16.5-BAK and allowed it to be recreated in case I'd messed up the preferences somehow, but I get the same results.
Does Indie not have the ability to view objects as subdivisions?
I can add in a subdivide node to actually subdivide the geometry, but that's it.
I'm sure this is a newbie question, but I'm pulling my hair out & just can't figure it out.
-Paul
Is viewport subdivision disabled in Indie?
9523 12 2-
- Paul Griswold
- 79 posts
- Midphase
- 833 posts
Works for me.
>>Kays
- Paul Griswold
- 79 posts
- malexander
- 5296 posts
- harryabreu
- 76 posts
- Paul Griswold
- 79 posts
I just checked again after reinstalling & the problem continues. I also checked the render tab (I'm just ctrl-clicking a Box to create the object) and it's set to Display As Subdivision Surface/Curves. Hitting Shift + on the keyboard or the + key on the numeric keypad does nothing except say “Turn On Viewport Subdivision” in the window.
I'm also using 16.5.496 Indie.
Thanks,
Paul
Thanks,
Paul
- amm
- 98 posts
It works here with Indie 16.5.378, however only for shaded objects, wireframe is left intact, above subdivided mesh. Somehow like old Maya smooth proxy, or Softimage poly mesh>subdivision. This is something new in 16.5 btw …. All that running ‘display as’ from render properties. I have to admit that, after four years I still don't know that much about 3d viewport shortcuts in H
Edited by amm - 2018年6月26日 14:44:38
- Midphase
- 833 posts
Paul Griswold
That's what I expect to see, but don't.
Maybe I'll reinstall Houdini and see if that fixes it.
I stand corrected. I thought I was launching 16.5.496 but instead I was launching 16.5.473. You are right, this is a bug in the latest version. We should probably file a bug report.
>>Kays
- pabcou
- 67 posts
- オンライン
- itai
- 29 posts
- raincole
- 696 posts
- kodra
- 373 posts
Still doesn't work for me in Houdini 20. Render tab option works, but Shift+= doesn't.
Edit: Houdini 20 changed how hotkeys work. Following this document [www.sidefx.com] fixed it for me.
Edited by kodra - 2023年12月1日 12:47:22
- DJEYzonnn
