Render transmissive object transparency?
2437 8 2-
- traileverse
- 371 posts
- 8239 posts
- 9576 posts
- traileverse
- 371 posts
tamte
I assume you should be able to use background B event in LPE
You obviously not get the refraction information but you should get the background contribution for the chosen lightpaths
Hello @tamte, Thanks for this but don't quite understand how to set this up.
I've added two images here, the one with black shows what I get If I just render the object with nothing in the background and the one with the white bg and white showing in transparent areas is me putting a grid object behind it it the render.
But I want to be able to render with nothing behind it and get the transparent areas instead of black to use this image on a website.
I've also added a hip file if you have the time to show how to set this up.
Thanks much!
hou.f*ckatdskmaya().forever()
- 9576 posts
- traileverse
- 371 posts
- razCHS
- 4 posts
tamteHello, where can I get some more information regarding the LPE tags that you've used (CT.*B)?
here is an example
1. added transmission_bg_mask AOV using LPE: CT.*B
2. combined it with Alpha in a slapcomp over custom BG
display slapcomp in the viewport to see the result
I've been trying to find this many times but got nothing.
Thx!
- 9576 posts
razCHSits not the tag itself, but LPE expression on Render Var
https://www.sidefx.com/docs/houdini/render/lpe.html [www.sidefx.com]
Edited by tamte - 2025年4月24日 09:38:08
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- razCHS
- 4 posts
tamteNever thought searching under Mantra chapters, always looked for it in Solaris or Karma.razCHSits not the tag itself, but LPE expression on Render Var
Thank you!
