Geometry Light in LOPs
   21940   30   10
In my test,Karma XPU still won't support geo/volume light.It's normal?
tamte
sekow
bump, LPE tags for geo lights still a no no?
you can tag geometry with LPE tag and then isolate in your AOVs
it works for geometry light contributions
the main limitation seems to be that the Split Per LPE Tag checkboxes don't parse geometry marked as lights, only light schemas and therefore they will not detect and create the AOVs for current workaroundish incarnation of geometry lights
so you have to create additional AOVs yourself with corresponding LPE that filters lights by LPE tag of the geometry light object
thanks Tomas, should have come up with that on my own, here is the hip for everybody that is interested. But not sure if my LPEs are correct, even if they look alright.
lops_geo_lights_aovs.hip (930.1 KB)
http://www.sekowfx.com [www.sekowfx.com]
sekow
If you always want to treat those objects as lights you can just do:
C.*<L.'tubes'>
but I assume your LPE tries to match both cases whether you interpret them as lights or keep as emissive surfaces
C.*[<L.'tubes'>+<O.'tubes'>]
in that case I think you can simplify by typing:
C.*<[LO].'tubes'>
CG Supervisor
Framestore, NY
Is there a way to control active radius on a geometry light?
tamte
sekow
C.*<L.'tubes'>
C.*<[LO].'tubes'>
Thanks! Its really helpful!
Bump for question about light linker -- is it possible to use Light Linker on geometry lights? I am trying to light link an emissive volume, but it's not showing up at all on the "lights" panel of the light linker...
オンライン
nicholasralabate
Not yet, but in a future release this will be possible, as Geometry Lights in USD are now decorated with an ApiSchema, so USD/Hydra recognize them as actual lights.
Edited by goldleaf - 2025年6月10日 18:01:45
I'm o.d.d.
Awesome! I guess the workaround now is recombining in comp, will stick to that until the ApiSchema recognition feature is added.
goldleaf
Good news. Please include it in the Light Mixer as well, thank you.
Is it possible to control attenutation? I tried linking it with the filter library to a geometry light and it seems it doesn't do anything.
devant
Light filters are not supported for geo lights (yet?)
https://www.sidefx.com/docs/houdini21.0/solaris/support/geometry_lights.html#limitations [www.sidefx.com]
