Lens shader not working when render to File/Mplay
   932   4   2
Hello, I have an issue with a relatively simple scene in solaris.
I have build a lens shader in cvex ( cylindrical lens ) that works perfectly in Solaris viewport (Karma CPU)
but fails when I try to render to mplay or to disk ( using a classical "Karma CPU setup" in solaris )
I can see lens shader related info in the usd at "Render/rendersetting" , everything seems alright to me.
  • karma:camera:lensshader -> op:/obj/....
  • karma:camera:uselensshader -> True
But it renders as if uselensshader was set to false.
Is this a bug ? or Am I missing something ?
I use
Houdini FX Version 21.0.508
On Windows 11
Looking at the log Viewer, I see errors :
Error loading lens shader: Unable to load shader 'op:/obj/cylindrical_lens_test/LENS_SHADER/gui2one_cylindrical_lens1'
Command Exit Code: 1
Error - lens shader must have P and I as outputs: Unable to load shader 'op:/obj/cylindrical_lens_test/LENS_SHADER/gui2one_cylindrical_lens1'
But my cvex network correctly outputs P and I vectors
Edited by gui2one - 2025年11月20日 15:01:55
https://vimeo.com/user43710534 [vimeo.com]
gui2one
Unfortunately, offline karma renders cannot use lens shaders defined by nodes, only those defined by HDAs, as they can be read from disk.
jsmack
gui2one
Hi, but my lens shader IS defined in a hda.the lens shader itself is a cvex VOP network though.
Is that the issue ? Should I write it in cVex instead ?
Or maybe my hda is not accessible to Karma somehow ?
... a little later ...
Oh I see, it's the "op:/obj/..." thingy that is the issue, right ? So Karma cannot load my HDA.
But that's not me referecing the shader using op:/obj/..., I set the property 'lens_shader_vop' on the camera I use by giving a relative path to my hda : "../LENS_SHADER/gui2one_cylindrical_lens1".
Edited by gui2one - 2025年11月24日 06:27:07
I assume you've read the karma lens docs? https://www.sidefx.com/docs/houdini/solaris/support/karma_lens_shader.html [www.sidefx.com]
There are some sample files that make use of custom lens shaders, they might shed some light on how to get it to render to disk.
I feel like it was working when I was playing around with a custom lens shader in h20.5
edit: Here is the one that I built, also using vop nodes https://www.sidefx.com/forum/topic/94084/?page=1#post-424757 [www.sidefx.com]
Edited by AslakKS - 2025年11月24日 06:41:18
Thank you so much for the tip. No, I hadn't fully read the docs.
And I didn't check "Save cached code" in my HDA properties.
It works perfectly now.
