karles22 – MatX-native Cycles render delegate for Houdini22
   600   3   1
Dear Houdini loving artists!
My name is Nikolaus Vuckovic, I'm a 3D/VFX artist from Vienna, Austria. After 20+ years of rendering in various engines, I finally built my own tool called karles22. It's a super fast Hydra 2 based render delegate bringing Blender's Cycles to Houdini 22 Solaris. It's MaterialX native, so there is only one node to learn: the karles22 Render Settings. It is built, optimized and tested for building new scenes with it, but you can also switch your existing scenes built with MaterialX. The result should match Karma pretty close.
Why?
I love Houdini, and since I'm mostly an in-camera 3D artist, speed, responsiveness, features like photon caustics, control over the final image and post FX like aberration, grain, halation, glow, streaks, ACES 8-bit bake ... are things I miss in other renderers. I packed all that, my 20+ years old render eyes and more into karles22.
This is not about being better than other tools. It's about getting more artistic control and final images without the need for comping. In many cases this is enough for projects.
Check out the video, and there is a demo version available at https://tools.immortal-arts.com/ [tools.immortal-arts.com]
Requirements: Houdini 22.0.466 (Indie, Core, FX), Windows, NVIDIA RTX 30/40/50 (driver 590+) or any 64-bit CPU.
Enjoy the speed, responsiveness and features of karles22
Cheers!
Nikolaus
Edited by immortalartscom - 2026年11月17日 06:34:14
Hi everyone,
karles22 1.1.0 is out. karles22 brings Blender's Cycles renderer into Houdini 22 Solaris as a native Hydra render delegate – your scenes, MaterialX materials and USD stages render with Cycles in the viewport and with husk, without rebuilding anything.
Free update for every karles22 license. Free demo and all details: https://tools.immortal-arts.com [tools.immortal-arts.com]
Want to test the full version first? There's a time-limited trial without watermarks until 15 December 2026 – write to support@immortal-arts.com and you get a personal invite.
What's new in 1.1.0
- Denoiser for steady animations (RTX GPU, driver 621 or newer): calm frames in the viewport and in husk, also with motion blur
- Lens Flare: ghosts, starburst and veiling glare of bright lights, traced through the lens
- RTX 20 series support (in the viewport, set Device to CUDA on RTX 20 cards)
- Motion blur of point, sphere, spot, rect and disk lights
- Gaussian splats: Color Space setting and HDR view-dependent color
- New AOVs: sss, shadow per light group, up to four Cryptomatte asset layers
- Texture disk cache with automatic tiled .tx files
- Missing Texture Color: missing textures show up in a color you choose (magenta by default)
- The viewport tells you when GPU memory is full and keeps rendering from system memory
- First start: a clear notice while the GPU shaders compile, and 8 GB cards with 16 GB RAM no longer run out of memory there
Fixed
- The viewport shows only whole images: fast camera moves no longer tear the image
- Cryptomatte files are written for every frame of a husk sequence
- Integer instance attributes reach integer geompropvalue nodes
- A camera with an invalid transform no longer restarts the render endlessly
- Distributed renders write the merged image only when it is complete
- Karma Sky Dome with Horizon Blur 0 shows the sky
- Houdini's Render Visibility presets work as expected
- Broken PNG textures no longer take huge amounts of memory
Your scenes keep their look: where the look changed, scenes saved with an earlier karles22 render with the old rules. New scenes start with Photon Caustics off.
Known limitation: with Photon Caustics on, the path-traced refractive caustics are left out. Both together come in 1.1.1.
Coming next: upscaling with quality modes for a much faster viewport.
Full release notes: https://tools.immortal-arts.com [tools.immortal-arts.com]
Feedback and bug reports are very welcome – here in the thread, on Discord (link in the customer area) or at support@immortal-arts.com.
Nikolaus
Do you include example scenes in the demo?
not atm. tutorials and demo scenes are planned. but basically it is 1:1 like working with karma and matx shaders. so the only thing/node to learn is the render settings. have you tried the demo yet?
