This is a very stupid newbie question, but please don't hit on the head
So I have created an object “torus” and i think the material “mantrasurfacd” is applied to it. But is there a visual way of validating the link between this object and its material? Or if not, is there a dialog in which I can find this info?
Gz
How to check if a material is attached to an object?
5178 5 1- Grendizer
- 375 posts
- Constantin X
- 136 posts
grendizer
Gz
There is a way. You don't find it in the tree/list view though as in XSI. Check the attached file. I have one sphere and one torus, each with his own shader. In the Material Palette pane select the shader and then click on ‘Select’ button. This will select all objects that have that particular shader applied to them. Hope this helps you.
C
- Grendizer
- 375 posts
- goldfarb
- スタッフ
- 3455 posts
- tamte
- 8597 posts
- Grendizer
- 375 posts
