19.5.711 Windows
When I right click-Save to save out a MaterialX file I get a script error
Child name is not unique: surface
Erro on saving MaterialX
692 2 0- art3mis
- 350 posts
- NicTanghe
- 193 posts
- Siavash Tehrani
- 710 posts
To be honest, I would say the .mtlx writing support is not really robust enough to be usable. I'd be curious if anyone else has experience to the contrary. From the docs: https://www.sidefx.com/docs/houdini/solaris/materialx.html [www.sidefx.com]
If you need to export .mtlx you could look into authoring MaterialX in the standalone QuiltiX editor: https://prism-pipeline.com/quiltix/ [prism-pipeline.com]. Apparently you can even use Karma as a Hydra delegate.
Solaris and Karma utilze MaterialX through UsdMaterialX, a plugin that allows USD to import MaterialX shaders. Houdini lets you build MaterialX materials in VOPs and translate them into a UsdShade prims automatically. While there is a script that can convert VOP nodes into .mtlx files on disk, the primary workflow Solaris supports, is MaterialX nodes encoded as USD prims. Solaris can reference MaterialX looks defined in .mtlx files on disk, but support for writing to .mtlx files is much more limited.
