Hi everyone hope your doing great.
I have a group which has an expresion that over time some of them randomly being selected.
after that i need to scale down each point in group that are selected to be zero. but not rightaway
i want to scale them down over some frames mybe 10 or 20 or...
so this piece of wrangle works:
if (inpointgroup(0, "mygroup", @ptnum))
@pscale *= 0;
but it's not what i want. i want to have control over the frame range i need the selected points be scale down
please let me know what is the best way to do it
thank you
Need an attribute wrangle vex
735 5 1- rain.man2294
- 3 posts
- animatrix_
- 4515 posts
You can write something like this:
float s = fit ( @Frame, 10, 20, 1, 0 ); @pscale = s;
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- rain.man2294
- 3 posts
animatrix_
You can write something like this:float s = fit ( @Frame, 10, 20, 1, 0 ); @pscale = s;
Hi Man Thanks a lot
It kinda works
you see the points will scale down by that frame range alright, but after that all the points scale down to zero.
I guess I need to store the points, when they are selected and when a point in frame 39 for example gets select, then from that frame that point should start to scale down to zero
how to achive that?
- Tanto
- 393 posts
Either you rewrite your expression to somehow be able to access the first frame your points enter the group. Then you can subtract that value from the current frame and use the result in a fit function as suggested.
Or you use a solver [www.sidefx.com].
Edited by Tanto - 2024年1月10日 13:34:32
- animatrix_
- 4515 posts
rain.man2294animatrix_
Hi Man Thanks a lot
It kinda works
how to achive that?
It depends on your selection logic. If you can determine it ahead of time, you can check for that in code. Otherwise the easiest way is to use the Solver SOP as Tanto said.
- rain.man2294
- 3 posts
Thank you guys,
I couldn't figur it out with solver but I manage to do it with this peace of code:
float start_frame = fit01(rand(@ptnum), $FSTART, $END);
float duration = 2.0;
float pscale = fit(@Frame, start_frame, start_frame + duration, 1, 0);
@pscale *= pscale;
works pretty good.
but the group random selection had to be removed which was ok for me
@pscale *= pscale;
works pretty good.
