create 'spider web' fracturing shape
   16464   12   1
Hi, i've been playing with shatter/fracturing, so far i always got quite random shape, i know i can control the density at specific surface etc. But right know i want to konw if possible , how to get specific shape of the fracturing, so i want the fracturing pattern like a spider web, it breaks from a center point and spread out. And the pieces also have a bit specific long thin shape, to be real , it's more like a crack on car's window when it's hit by a bullet, you'll see ‘spider web’ pattern. Any idea ?
thanx
hm, sounds to me like a job for a clip-sop/foreach-sop combination. If you
want decent control over the fracture do it manually. but maybe I'm wrong
There is an example of this type of clip/foreach tool in this dvd - for 2D cases:
http://www.3dbuzz.com/xcart/product.php?productid=58&cat=0&page=1&featured [3dbuzz.com]
If you want it in full 3d I would go with a high resolution voronoi split, but group pieces together to get the concave shapes. required for those rounded pieces. The way you scatter your initial points for the voronoi will be important too.
https://www.linkedin.com/in/peter-claes-10a4854/ [www.linkedin.com]
try this I used it recently and it works pretty well.
make a couple of circles with a limited number of points. say 5 or 7
overlap them slightly and align them to the surface you want to shatter.
pipe their points into the points input of the voroni shatter sop.
and run the shatter.
you should get a radial like shatter from this pretty well.
depending on how you move things around in the points you should get some nice radial shards out of this, if you put a small amount of scatter points on there too, it will start to break up things nicely .
I don't have any time right now to make a hip example, but this should work pretty well for ya
-johnc
hi ,
to have more control ( frequency or orientation ) , you might use a simple sphere too …
.cheers
Hi guyz that's soo COOL … exactly what i'm looking for. thanx a lot. I'm working on it now. Well it's a bit tricky to get the shape i want. But i got the idea.
Thanx
hi ,
started as a curiosity to consume and just figured out how to build a spiderWeb DA . if not complete , there is the skeleton .
let me know if you need it .
love houdini
.cheers
zarti
hi ,
love houdini
.cheers
Hi Zarti,
yes i like to try it if you don't mind, thanx for sharing anyway
here it is ,
its parameters are over the ‘ DONE ’ null node .
those names aren't so clear , but play with the sliders to see what they do .
.cheers
spiderWebShatters_002.hipnc (120.5 KB)
zarti
here it is ,
.cheers
Hi Zarti thanx a lot for sharing. i'll try and see if i hit a problem then i'll be back.
thanx
not sure if you missed something in the final HIP file but I could get it working only by changing your forvalue expression with the default one:
stamp(“../../foreach1”, “FORIDXVALUE”, 0)
stamp(“..”, “FORVALUE”, 0)
loading the scene with your expression gives me warnings on load and then doesn't seems to work. check it out!
edit: btw, such expressions where in the pointJitter and in the ROTATE nodes inside the foreachSOP
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
hi sum][one ,
strange i never got any message when i reloaded the hip , even with the one uploaded here . also , there was nothing removed from the hip file before uploading it .
my experience with houdini is modest , so i'm unable to explain why that happened or how i could avoid a similar thing happen again in future
thank you for the correction .
.cheers
After messing around, got some decent pattern….
maybe useful to you.
bulletHit_pattern.04.hip (150.1 KB)
