Hi, I´m working in a hip file for some weeks. While I was switching between takes to render different things an error shows up when I render a SOP node with some particles. The weird thing is that if I render a frame range with the start frame higher than 4 it works, frame 1 doesnt. I know is this node because if i disable it everything works fine. If I launch the render from the window menues i get this error.
EDIT: I have noticed that frame 5 is where first particles appear
EDIT2: Actually it fails when there are no particles in the node
Any idea what going on with this? thanks in advance!
Error starts appearing when rendering
3229 4 0-
- nzabala
- 66 posts
- circusmonkey
- 2624 posts
- nzabala
- 66 posts
- nzabala
- 66 posts
There was a problem with the parameter I added to the Material SOP after the POP network where i added the “lightcolor” to get the variation. Thats not the attribute i need so its my error there. I removed the attribute, unchecked the base color and enabled “Use Point Color” on my shader and now works.
The error showed up but I was doing the things wrong, so maybe there was something missing and thats why the renderer got confused.
Sorry for rushing in getting troubleshooting, it was a long night working in that
NicoZ
- circusmonkey
- 2624 posts
