Object Normals Issue
2860 4 0-
- bfikkert
- 8 posts
I have a series of boxes setup in Houdini that I want to render, they were just polygons at first but when I rendered them, Mantra was smoothing the normals and it looked fairly bad (original.jpg). I then added a Vertex sop and turned on Cusp Normal, this gave me the look that I want to achieve (polygon_wCuspNormal.jpg).
Unfortunately I can not use polygons because I need to fracture these boxes and I need more subdivisions to do that. Switching to polygon mesh and increasing the subdivisions causes the normals to mess up again (polygonMesh_wCuspNormal.jpg). Does anyone have any ideas how to fix this?
- circusmonkey
- 2624 posts
- bfikkert
- 8 posts
- circusmonkey
- 2624 posts
See attached for some options using the facet SOP. If you use the vertex sop and displacement in your shader you should look at this example. http://web.me.com/circusmonkey/circusmonkey/Shops.html [web.me.com]
of note > images in your post should be smaller > as it makes viewing your post awkward.
Rob
Rob
Gone fishing
- bfikkert
- 8 posts
