I want to bake occlusion data in a pc file. The ideia is to render the whole scene from a bake cam and later render the actual image from another camera.
My problema is the occluded surface (Enable Hidding is disable) that is not rendering right, how you can see in the images below.
The hip and otls attached in this post is a modified version of the files that I got from http://www.circusmonkey.com.au/circusmonkey/PointClouds.html. [circusmonkey.com.au] (I add two takes, read and write, besides other things)
I try change the radius and number of points in the pcopen function but so far is not work.
So, can you help me?
Point Cloud - Bake occlusion
3119 2 1-
- alves_mauri
- 18 posts
- circusmonkey
- 2624 posts
- alves_mauri
- 18 posts
