How do you get a progress report when rendering with HBatch for the command line, I'm on a mac if that matters, any help would be greatly appreciated! This is the command I'm currently using.
mread filename.hip
cd /out
render mantra1 -f 250 275 -V -n
all that this does is say: Rendering mantra1.
Which is painful as I never complete a render at once, and don't want to go browsing my computer to see where it's at.
HBatch Progress Report.
12333 15 1-
- anon_user_63541013
- 197 posts
- 197 posts
- edward
- 8086 posts
- circusmonkey
- 2624 posts
- 197 posts
- Erik_JE
- 300 posts
Delight0092
For some reason the frame range I specify is overwritten by the one inside the Hip file, how do I make the -f one the one it renders?
Also it didn't work.
This exact string.
render rop_geometry -f 87 300 -Va1 -s
You need to do it as:
render -f 87 300 -Va1 -s rop_geometry
Then both verbosity and framerange will work.
Drive, monkey, drive!
- 197 posts
- Erik_JE
- 300 posts
- 197 posts
- edward
- 8086 posts
- edward
- 8086 posts
Delight0092
Also how would I schedule 2 renders, so I can specify a Geo ROP, than give it a mantra to render render?
Connect the Geometry ROP to the Mantra ROP. Rendering the Mantra ROP will now cause the Geometry ROP to run first, followed by the Mantra ROP.
http://www.sidefx.com/docs/houdini12.1/rendering/renderdependencies [sidefx.com]
- 197 posts
- edward
- 8086 posts
Delight0092
Thanks, but it's impossible, rop geometry is in a different context, and i don't think I'd be able to do this through HBatch, I'll go the python route, but don't know where to start!
http://www.sidefx.com/docs/houdini12.1/nodes/out/fetch [sidefx.com]
- 197 posts
- edward
- 8086 posts
- 197 posts
guess there is some funky argument parsing going on.
