Houdini and Multi UV Tiles
   37963   31   2
Hello, I've done searches for this but got to a dead end. Does Houdini support Multi UV tiles? I have a model in Mudbox that has 2 Tiles what is the work for for bringing this into houdini?
Thanks.
Ok, I think I just figured it out, make two materials and merge them? It seems to be working perfectly fine for me.
Actually what you have there will result in duplicated geometry (the merge will effectively double the geometry) and likely result in render artifacts from the doubled up polygons.
You can apply multiple materials inside a single Material SOP without needing the merge…
Peter B
Peter Bowmar
____________
lol, yeah I just realized that. For some reason it doesn't work when I do it both in the same material node… and idea?
Sorry, I'm not really sure what you're trying to achieve and what the data (model) is coming in… when you say 2 UV tiles, do you mean differently named UV sets? Or the UVs go 0-1 and then 1-2 in value?
Peter Bowmar
____________
I have a model in mudbox that i sculpted, exported that as a .OBJ and imported into Houdini (when I goto the UV view in Houdini two tiles show up as shown in Mudbox). The I set up the UVs in mudbox to have two UV tiles (http://download.autodesk.com/us/mudbox/help2010/images/MED/Dragnet/English/Painting/comp_uv_multitile.png). [download.autodesk.com] I exported a displacement map out of mudbox, two separate displacement maps were created for each UV tile. My question is how do I set this up in houdini to displace using two separate displacement maps.
I hope that cleared things up, thanks!
Ah, OK. So in Houdini terms, your UVs are 0->1 in U and 0->1 in V for the lower left tile, then the next tile to the right the coordinates are 1->2 in U and 0->1 in V.
Unfortunately, there is nothing that handles this natively that I know of. You'll need to get into VOPs (the shader nodes inside the Mantra Surface material) and modify the default to have several displacements using different UVs.
I think the First Steps tutorials that Ari did take you through that:
http://www.sidefx.com/index.php?option=com_content&task=blogcategory&id=203&Itemid=362 [sidefx.com]
Peter B
Peter Bowmar
____________
Correct. Thanks a lot I'll check that out.
Can you send me the geometry file or another file with the same setup? I think I know how to deal with this but I would need to check if this works with the setup you have in your model.
Please include the displacement maps for reference.
Robert
(rmagee@sidefx.com)
rmagee
Robert
(rmagee@sidefx.com)
Thanks, just PMed you
The most efficient way i have dealt with this is through VOP's.
I use UV transforms and TwoWay's to turn textures on or off. It's kind of a pain but it works. I have tried to get the Multi Parm list working in the parameter editor, so all i need to do is click the “+” icon to add a texture and set the UV space but i failed.
Maybe i should give it another shot because switching over to H12.5 i had to re-edit my skin setup. And bundling this into a VOP asset, would make things a lot easier.
Here is what most of my parameters on my skin shaders look like
edit/ I am interested in seeing Robert's method too.
blog [abvfx.wordpress.com]tumblr [andrewbrowne.tumblr.com]twitter [twitter.com]
I kind of prefer named UV sets. The biggest problem being that you have to essentially hard-code them into your shader, or leave your VOPnet live which can be painful speed-wise. Though much better in 12.1 and 12.5.
Peter Bowmar
____________
Yep its a pain .
I'm not quite sure i fully understand you when you say named UV sets? You you referring to my naming “face”, “back” “L_Leg” etc? I only do that to make it easy on file referencing usually the naming is just character_diff_u$v$.tif
Is there anything i can do the make this easier/streamlined?
Sorry what I mean is, the actual ‘uv’ attribute on the geometry. So instead of ‘uv’ and ‘uv2’ etc on the geometry, I prefer ‘uv_head’ or ‘uv_leg’
Of course that can be cumbersome when working with external apps like Mudbox or 3D Coat…
Peter Bowmar
____________
Any chance doing something like that with PythonSOP?
Attached is a .hip file I sent earlier to hereacoon which demonstrates a solution to this issue. It is setup for his particular example file (which he has generously allowed me to share here) where the tiles are only going in the U direction. If your tiles go in U and V then you would have to extrapolate the solution.
http://www.sidefx.com/images/stories/transfer/uv_tiles.zip [sidefx.com]
You can find the solution by double clicking on either the Mantra surface or the Surface Model materials. The first shows the displacement when assigned to your geometry while the second would show a black and white representation of the displacement value assigned to Diffuse.
In both cases, the textures are applied using VEX. The U coordinate is turned into an integer then the UV is subtracted from that integer. This way if the U value is bigger than 1 it gets shifted into 0-1 space. Meanwhile the integer value +1 is used to get the appropriate texture map using the print1 node (this is also where the texture maps name and path are assigned). If the integer is 0 then you get texture 1. This also works after we go past 2 or 3 or 4 etc…
I hope this helps. I had developer help with this. I wouldn't have figured it out otherwise. I had tried a solution using UV layers but this turned out much simpler.
Robert
Big Thank you for the brilliant solution
It would be nice to have a Udmin based VOP for Houdini's shaders to interface with Mari and Mudbox
Rob
Gone fishing
hi guys i dont if you got yours working since this thread is about a year ago.
but really just create texture vops for each tile and feed its “s” and “t” with
a uv transform node
1st tile is translate x = 0
2nd tile is translate x = 1 and so on (moving from screen left to right)
and then add them together, just dont forget to set the texture nodes to decal.
tested it with 4k VDM from zbrush works great
best of luck
kiel
Feel free to post up a scene file showing your technique !
Rob
Gone fishing
