Why won't this ramp parameter work?
4504 4 0-
- KMcNamara
- 228 posts
- Sadjad Rabiee
- 1391 posts
- KMcNamara
- 228 posts
- 9376 posts
the rampTest node under /VEX is just the definition of your shader
the actual instance of that shader which you are using to shade your curve is in /SHOP/rampTest1 so you need to tweak ramp on that node instead
and maybe rather than defining your shaders as VEX Shader Types (which is quite old way of working) you can just build them directly in SHOP context and convert to HDA if you need more instances with the same UI
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- KMcNamara
- 228 posts
